RCU Forums - View Single Post - Problem getting out power from webra 1.20
Old 04-09-2006 | 11:30 PM
NM2K
My Feedback: (14)
Default RE: Problem getting out power from webra 1.20
ORIGINAL: niche
Hi Ed
It sounds like you know a lot about engines
After quite a while I was ble to understand what you meant by your suggestion of checking whther the cylinder sleeve's ports were alligned with the ones of the crankcase.
I dismounted the muffler and saw a couple of rectangles with a space in between which I think it's the right thing to be sawn here.
I am attaching the picture I took and the exploded list webra posted for this engine(see link below) they look like they are ok
http://www.webraengines.com/motor.ph...e=AERO&lang=EN
Hope I am in the right path
Appreciate anehy help from all around to find out what's wrong with my engine
Regards and thanks again
Omar
I don't have a Webra 1.20 with which to rotate the cylinder sleeve and make a comparison, but in your picture that does look real good (correct).
I'm scratching my head trying to figure out what else could be wrong.
