RCU Forums - View Single Post - 9Z Case Foam
Thread: 9Z Case Foam
Old 04-10-2006 | 09:32 AM
Krysta
Default RE: 9Z Case Foam
Hi Ka3muf,
We are not sure of the dimensions of the JR foam, but of course it simply needs to be the same as the original inserts for the 9Z case.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: Ka3muf
I need to replace the foam in my 9Z case. I want to use a factory replacement, not the pull-apart stuff. If not available from Futaba, would the JR replacement fit adequately?
