Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9Z Case Foam
Old 04-09-2006 | 10:30 PM
Ka3muf's Avatar
Default 9Z Case Foam
I need to replace the foam in my 9Z case. I want to use a factory replacement, not the pull-apart stuff. If not available from Futaba, would the JR replacement fit adequately?
Old 04-10-2006 | 09:32 AM
Default RE: 9Z Case Foam
Hi Ka3muf,
We are not sure of the dimensions of the JR foam, but of course it simply needs to be the same as the original inserts for the 9Z case.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: Ka3muf
Old 04-10-2006 | 06:15 PM
My Feedback: (13)
So, by that reply one could assume that no original replacement foam inserts are available?
I need one myself...
Old 04-10-2006 | 09:10 PM
Ka3muf's Avatar
I have determined that the case foam replacement offered by JR will fit the Futaba case with little or no modification/addition of foam. To me, little things like this will make a big difference when it comes time to make a new radio selction.
