RCU Forums - View Single Post - 8UAP and twin elevator servos
Old 04-10-2006 | 11:53 AM
Krysta
Default RE: 8UAP and twin elevator servos
Yes this does negate the channel 8 knob when this is activated:
Use the ailevator function, designed for just this purpose.
Plug servos into 2 and 8
Go to AILEVATOR
Make the function active
Test your elevator movement. If one is going the wrong direction, reverse the % for that servo (ie -100%).
IMPORTANT READ ME: Do you want your elevator servos to also act with your ailerons? If NOT, you must reset the AIL3 and AIL4 numbers to 0.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: bobswika
Hello,
Does anyone know if this disables the channel 8 knob? Thanks.
