RE: Controller Setup for 3d Helicopter
Hi
Have you managed to get the controler working? working on a plane?
Once you have calibrated, go to controls, double click on the one you are using, and look for auto-rotation, if you have a tx with more than 4 channels, move the button on and off that you want autorotation on, and put the dot in line with the red bar that moves when you do that and also in line with autorotation.
if you have a 4 channel tx, you will have to use a number on the key board in stead of a switch
there you go
regards
Martn
