RCU Forums - View Single Post - Problem getting out power from webra 1.20
Old 04-10-2006 | 02:58 PM
NM2K
My Feedback: (14)
Default RE: Problem getting out power from webra 1.20
ORIGINAL: niche
Thanks for the concern
Actually it had stuck ring and I loosened it
I ignore for how long was the ring stuck but I am thinking it yielded an uneven wear in cylinder sleeve.
I am thinking about getting a new cylinder/piston/piston ring assembly
Do you thinks it's woth it to replace them?
Regards
Omar
If the cylinder sleeve isn't obviously damaged, I wouldn't replace the sleeve. That is the beauty of ringed engines. Most times, all you need is a new piston ring.
With ABC engines you need to replace both the sleeve (liner) and piston as a unit. Not so with ringed engines, unless there is obvious damage that you can feel with your finger.
