RCU Forums - View Single Post - Rusty Bearings
Old 04-10-2006 | 03:47 PM
  #36
Ernie Misner's Avatar
Ernie Misner
Default RE: Rusty Bearings
Be careful with the electric starter after using lots of after run oil in a 2-stroke. You can hydraulic lock the top end and bend or break the rod/crankpin easily. A short blip will do it, and even then you will notice the compression has increased drastically on an upright engine. Inverted would be even worse I imagine.
Ernie
