Another quick question guys:
How did you all attach your Twist canopies? Early on in the thread someone recommended Goop glue - is this the best option? I do have some, lovingly borne across the Atlantic from Canada... Or I could use UHU Por, which might be even more flexible.
I would sort of prefer to have the canopy removable though - has anyone screwed their's on?
I really wish I'd thought to buy a pilot. I guess I'll probably end up doing one of those cartoon profiles of Calvin and/or Hobbes or something. Unless of course someone can suggest a way to make a proper pilot in less than half an hour or so, because that's probably about the limit of my patience.
Thanks again, I'm almost there!
Matthew
EDIT: Btw, after consciously deciding to make the lower servo hole the rudder, I then went and put the horn on the wrong side.
Looking at the geometry, either way should be fine, but boy I feel dumb sometimes.
