RCU Forums - View Single Post - Seagull Models Edge 540
Old 12-17-2002 | 09:27 PM
  #60
ptarp
Default Seagull Models Edge 540
I have seen engine mounts that have special rubber pieces to reduce vibration wear on airframe. With one of these, do you think that a 120 fs(if it will even fit) would be ok, or still too much. At a possible 9lbs, I just think a 91fs wouldn't be enough, and I don't want a 2-stroke.
wolf... 3.3kg = 7.27lbs!!! What did you do to get it this light. The webpage says 8-9lbs, I have never seen anyone overquote a models weight.
What scale pilot should I use? 1/5?
P.S. Any suggestions on specific hardware replacement would be super.(4-40?)
