Originally posted by ptarp
wolf123, would you suggest the 91fx over the 1.08? The 91 should have more than enough power, shouldn't it?
I just ordered a Futaba 9C radio. I'm still confused how it would be able to reverse a single servo through a Y connection(if I was using two for the elevator, for example). Or, do you put them on different channels and mix them together?
Yes, You should put them on different channels, the same was you do your 2 ailerons. Its nice that way too, because you can adjust each elevator half independently if you want to.
