pull pull
for those of you that installed a pull pull rudder was there any problems installing it, and did you put the cables in tube the full length of the fuse or just where the cables come through the fuse. I was jut wondering because I see in the fuse the last former all the way in the back may need to be dealt with. So far I'm very impressed with this arf as I'm putting it together. I'm really looking forward to completing it. Should I be looking out for weak spots that need attention with epoxy or CA? After seeing some of the items here I'm going to glass the center of the wing. Thanks for all the input in these thread so far it has been very informative.
Mark
