RCU Forums - View Single Post - Should I send it back?
Old 04-10-2006 | 10:18 PM
ryan_t888's Avatar
ryan_t888
Default RE: Should I send it back?
It does not sound like you have any of the "air leak" signs/symptoms.
When your priming it, give it a bit of throttle. This will make the fuel flow faster as the LSN will exit the spray bar a small amount. Also give it a bit of throttle when starting it up after it has been running.
Ryan
