RE: flaperons?
flaperons are a type of mixing, and as long as your transmitter can do it, 9c sure will, and your ailerons are 2 separate servos it should be alright. As far as the flaps go, I suppose you would have to mix your flap settings into the ailerons, which should work fine.
