RE: Hangar 9 Twist 3D
Sounds like some good ideas. I want to put some bracing in my Twist as well. I have read that you want to brace the firewall to the fuse with blocks or triangles using CA or epoxy. Sounds like the landing gear is another area that needs help. Any other spots worth shoring up?
Test ran my OS 61 FX yeterday. Boy does that motor run smooth. I am used to an LA. But the FX is more responsive, and just sounds nicer. I was amazed at well it would idle at a very low RPM.
Adam
