RE: Covering Problem
I've ALWAYS used a product called Balsarite to seal the wood on planes before I covered them. I also use it to fuelproof the engine and fuel tank areas. I also use it in areas like the wing saddle where the covering ends. A side benefit is is helps the covering stick to the wood much better.
