Seagull Models Edge 540
Hi rcav8r4 - I have been through the whole package and the instructions say "spinner and backplate" but there is no spinner in the box. The motor mount is attached to the fuse but as I said its too short for a 4 stroke. It looks like a nylon type - kinda cheap so I'm going to use another one regardless.
I also thought the landing gear is cheezy - its two thin pieces of aluminum bolted together to make a thicker one. I'll dump that too. Too bad in an AFR that's so expensive.
Check on the Seagull supplier or the hobby shop and pls let us know.
cheers
tfacr
