RCU Forums - View Single Post - Piston Replacement on 1.60 FX
Old 04-11-2006 | 01:51 PM
NM2K
My Feedback: (14)
Default RE: Piston Replacement on 1.60 FX
ORIGINAL: FentonFlyer
I posed this question to Bax in the O.S. forum too, but I thought I might give this one a try also.
Can I just install a new piston and ring without replacing the cylinder liner?
My cylinder is in pretty good shape, however my piston is scored(used engine,never again ).
Anyway, my thought was to just use a BB style brake cylinder hone or a homemade flap wheel to just "break the glaze" in the cylinder.
Any thoughts?
Absolutely. If the liner is in good shape, all it needs is a piston ring, assuming the piston's ring land is okay too. You did look at that, didn't you?
Go very easy with that brake hone, but you knew that.
