RCU Forums - View Single Post - ys 110 break in
Old 04-11-2006 | 08:02 PM
Dave Shadel
Default RE: ys 110 break in
Take the fueling valve out of the system, NOW! They will develop leaks and cause you nothing but problems.
Use T fittings and fuel dots. One between the filter and the tank on fuel side, one between the check valve and the tank on the pressure side. Pull the plugs and fill thru the fuel side, the pressure side becomes the overflow. Simple.
