RE: Programming an ESC for Lipos
Not the exact same controler but try this Also an e-bay esc
TOWERPRO CO.LTD
BMC SERIES BRUSHLESS MOTOR CONTROLLER
SETUP MENU (only for 40A, 60A, 100A, 140A)
Type Current Fe t BEC Timing mode PWM LIPO NIHM
40-N 40A/60A 18 5V/4A 3/8/15/30 8/16/32K 2to5 6/18
60-N 60A/80A 24 5V/4A 3/8/15/30 8/16/32K 2to5 6/18
BEC work under 3LIPO(10cell NIMh/NiCd)
5LIPO or 18 cells NIMh/NiCd MAX with BEC disabled
First, connect the motor and receiver to the speed controller
Remove battery power from the speed controller.
Turn on the transmitter.
Move throttle stick on full power position, (UP Position)
Reconnect battery power to the speed controller
After 3sec you can hear (all sound is 3times)
∮— CELL Type AND Number
∮— — BRAKE
∮— — — TIMING MODE
∮— — — — PWM
ON you need programming menu, move the throttle stick to the middle position
1, CELL Type AND Number
•— NiMh/Nicd AUTO(0.8V/CELL*)
•— — 3LIPO (2.75V/CELL)
•— — — 4LIPO(2.75V/CELL)
•— — — — 5LIPO(2.75V/CELL)
*IF used 2LIPO you can use the option (select the NiMh/Nicd AUTO)
2, BRAKE
••— NO
•••— — SOFT
•••— — — MID
•••— — — HARD
3, TIMING MODE
•••— 3º
••••— — 8 º
•••••— — — 15º
•••••— — — — 30º
4, PWM
••••— 8KHZ
•••••— — 16KHZ
•••••••— — — 32KHZ
IF the option is you need, then move the throttle stick to UP position.
The long BEEP is save the option. and the system will go to the programming menu.
You can setup other options.
When all you need option is setup OK, push the throttle stick to down position, after 1sec the system were save all option, then you can start the motor now!!
Hope this helps good luck
