RE: Rusty Bearings
You'd be surprised how easy it is to detect radial play using this technique -- especially if you're using a larger diameter prop. There should be virtually no perceptable movement on good bearings but once they start going bad the movement begins to increase quite rapidly and can usually be picked up before they start screaming or grenade.
