RCU Forums - View Single Post - Rusty Bearings
Old 04-12-2006 | 01:09 PM
  #52
sfsjkid's Avatar
sfsjkid
Default RE: Rusty Bearings
Probably a combo of both, you'll feel it if it is bad enough, but won't if it isn't. Last time I experienced bearing failure, engine was running close to normal, just making a rapid but soft "kunking" sound, no play in the shaft at all. When I took the bearing out, found that the little fingers that sandwich the bearing cages had started to come apart ever so slightly.
