RCU Forums - View Single Post - 3W-24 Gas Engine in Rascal 110
Old 01-23-2003 | 02:40 AM
captinjohn
Default G26
RCIGN: How many degrees of advance are you running on that engine? If a person was to advance the timing on a mag type.... could you remove the key and use a dab of locktite to make sure the timing stays the same? How far does the offset off the keyways appear to be? Thanks Captinjohn
