RCU Forums - View Single Post - 3W-24 Gas Engine in Rascal 110
Old 03-03-2003 | 09:57 PM
augiep38
Default 3W-24 Gas Engine in Rascal 110
The manual calls for 60 ounce servos on ailerons, rudder, and elevator. The 4721's are overkill, but it beats buying servos when you don't need to.
The firewall is around 4 5/8" wide and the cowl is the same width.
If your muffler is 5 1/8 wide, you got 1/2" sticking out the side of the cowl, and if its the same as mine, it won't be just one side. It will be centered up so that there is about a 1/4" sticking out each side.
I am thinking about getting a small header to put on the engine and some flex pipe to run out the bottom of the cowl.
I don't know how this will affect the engine performance though and I imagine it might not get past the field noise police.
If anyone knows of a muffler that will work without butchering the cowl, please let me know.
Todd
