RE: YS 110 Quits at idle
Seanychen:
Your advice was right on. I HAD this problem with my latest new 110 and after reading your post, I checked and adjusted the regulator to 3 turns out from closed. It was at about 1 1/2 turns out before changing. I re-set the high and low speed needles to 1 1/2 turns out and my 110 fired right up and ran beautifully for 8-10 flights today. The only adjustments made from the above is that I richened the high speed by 2 clicks and leaned the low by about 1/8 turn.
This advice saved me a ton of headaches as there is little or no good information from YS that I have seen on dialing in the regulator setting.
Thanks again! Happy flying!
