I don't know why but I've problems running the map423 calculation sheet. The addins are installed but it's not working anyway.
Can someone do this work for me
before I'm going crazy? Or give me hints to get this sheet running...
My ignition is built for the Zenoah G260 PUM.
As described in the manual idle rpm is 3000rpm
advance timing is 30°/7000rpm
What advance timing values are you people using? I made some considerations about optimizing output of my G260PUM. What do you think?
-To start engine easily, advance timing at 0-2000 rpm should be 0°or even after TDC.
-max. rpm should be at 20.000rpm (=no rpm limiter)
Thanks for your replies
