RCU Forums - View Single Post - SSE Gap in Wing/Fuse
Old 04-15-2006 | 11:48 AM
MasterAlex's Avatar
MasterAlex
Default SSE Gap in Wing/Fuse
Okay guys, I have been following all these SSE builds for several months while I built my own SSE. I have certainly learned a great deal from RCU which has save me countless errors I can assure you!
I have now reached a somewhat major milestone in my SSE build (pic #1) - I now have something that actually resembles a plane! This thing may fly after all!
Anyway, when fitting the wings to the fuselage my elation quickly faded as I discovered a gap between the fuselage side and the wing root. Not all the way down the root, however. This is true for both the top and bottom of each wing. I have some pics that hopefully describe:
Picture2 - Top Right Wing. Flush with fuse for about 1/2 the length, then it pulls out at the leading edge.
Picture3 - Scale reference. Looks like 1/16" gap.
Picture4 - Bottom Right Wing. Not nearly as flush as the top portion of the wing.
Picture5 - Scale Reference. Again the gap is approx 1/16".
So, how bad is this?
How should I proceed? Should I try and sand down the "high side" and try to get the wing to go flush?
I worry about changing the aerodynamic portion of the wing/fuse relationship and fear the "fix" might be worse than what I perceive to be the problem ... know what I mean?
Thanks for the help!!
-Alex
ID:	445718   Click image for larger version
ID:	445719   Click image for larger version
ID:	445720   Click image for larger version
ID:	445721   Click image for larger version
