RCU Forums - View Single Post - Senior Telemaster ARF modifications
Old 04-15-2006 | 10:21 PM
MikeFreas
Default RE: Senior Telemaster ARF modifications
Progress on the ARF is nonexistant at this point. I did make it to the hobby store to pick up some wood to make the needed modifacations. I also cut out the bottom sheeting in the fusalage right behind the gear reinforcement plate. I'm still not 100 percent sure how I'm going to modify the forward half of the wing to make it a bolt on. I may carefully cut out the forward most inner rib on each side and fab up a hardwood piece with a tongue like my other design. I'm almost sure the servos are going in the tail but that will require some more work. I'm on travle next week so nothing will get done. When I get home I'm going to hit it hard to get back in the air.
