RCU Forums - View Single Post - ARROW TIGER 40-52 LIFT PROBLEM
Old 04-16-2006 | 03:23 PM
krammer
Default RE: ARROW TIGER 40-52 LIFT PROBLEM
Hi tIANci ,
I`m using a 10.5x7 ARC prop and the motor has just been run in,
When i say go vertical you will be flying at a level path and then you pull up the elevator to go vertical the plane will raise the front by only about 100mm - 200mm then it drops back down?
