RE: Hammer replacement engine
I dont believe so, the crank in the regular one is probablly missing the little Pin on the back that the starter shaft keys to to turn it over, so till you got that and a crank itd be cheaper to buy the pullstart version, I could be wrong but I'm fairly sure thats how those are... I know some car engines are like that, saw an article on converting to bump start and they said cut the little pin off, so id assume all non pullstarts do not have the pin, you could call OS up and question it...acutally look at the parts for it on tower and see if the cranks are the same if you can see the back...
