RCU Forums - View Single Post - CMP (Raiden Tech) ARF's
Old 04-18-2006 | 01:06 PM
Messerschmitt's Avatar
Messerschmitt
My Feedback: (28)
Default RE: CMP (Raiden Tech) ARF's
Yes, I have flown mine twice. It is balanced, but flies as if it where very tail heavy. After carefully checking the horizontal stab and wing, I have found that the Horizontal stab is negative 1.5 degrees (on leading edge). This is what produced the "tail heavy" flight charicteristics on mine. I did not assemble the plane, like I said, I purchased the plane from another guy in my club. I don't know if this is a manucatering defect, or bad assembly. In any event, I will have to pull or cut the horizontal stab off my plane and place it back on correctly. I would advise carefully checking your plane (if you have not already done so).
Please PM me and let me know how it flies.
good luck!
Mike
