RCU Forums - View Single Post - CMPro Lancair
Old 04-18-2006 | 08:20 PM
  #51
bjor's Avatar
bjor
Default RE: CMPro Lancair
Hi Todd,
I have the CG set between the manufactures guideline - 72 and 78 mm from leading edge and about 60 MM from fuse - though the distance specified from the fuse is not mentioned in the instruction sheet. I have set the CG at 75 mm, tested with the plane upside down, and drooping at the nose (tank empty) by about 15 degrees. I have also used the throws as suggested by tIANci above as these worked fine. You are right about the cross over on the pull - pull rudder - your eyes are obviously better than mine. I was thinking of changing it back but it means setting up the front wheel again so I'll leave it. Have you ever had an issues with crossed over wire on Pull Pull cables, I was wondering if the potential was there for stay wire barbs to snag the system. Brad
