RE: Next Steps programming DX6 and Trex SE??
Crazy Hammer.
In the write up you don't seem to mention adjusting the Gear value to +45% while the aileron DR switch is set to 0. What do you set the value to when the switch is set to 1?
I assume if the wag is to little or to much you adjust the 45% up and down till you see where wagging stops.
JD
