ORIGINAL: consultjdm
NVSFlyer,
I want to hook my 401gyro into my mode switch. So I have it on "F" for my TREX.
I want heading hold in both modes but different amounts of hold. I think it was suggested to run a little higher gain with minor wag in 3D. But really I just fly mostly in mode 1 and hover around.
Would I then go into gear while in normal mode and set it to about 50%?
I have a showgun also with an EF Gyro. Using the mode setup above if I turned the percent up above zero it caused intense wagging and seems kinda okay at zero. I am not sure if I am missing something here.
JD
Unlike some of the other TX's that have different setting for Normal or Idle up ours don't change when switching modes. I've looked and tried a bunch of things more looking for different piro rates for different modes but was unable to find a way. As for the EF Gyro I'm not sure if it works with ATV mode like the 401 maybe take a look and see if it does.
As for the settings I have my Aileron D/R switch is in postion 0 and about 40% if I get above this I have a small wag and if I go below this it won't hold. If I plan to do 3D I run about 50% and deal with the wag because the tail will let loose a little on mine if I put hard throttle input this maybe due to running 315 M/R blades and the tail can't put enough into it.
Good luck
