RCU Forums - View Single Post - XP6102 Setup
Thread: XP6102 Setup
Old 04-19-2006 | 09:09 PM
hooaa's Avatar
hooaa
Default RE: XP6102 Setup
Joe,Thank you for the tips. I have the Gear on the upper left switch. The LED on the gyro does not react to TX switch commands. The LED blinks about once every two seconds regardless of setting of gyro gain. I will remove it and get a paint job on the creature. The last problem involved thr masthead. It's built correctly, and checks out statically, but as headspeed passes a high sounding level it just makes a good cooling fan.
Roland.
