RCU Forums - View Single Post - Problem!!!!! HElp!!!!!!
Old 04-21-2006 | 10:02 AM
arghc10
Default RE: Problem!!!!! HElp!!!!!!
check the clutch to see if the shoes are melted or if the springs are weak of broken. you want at least a 1mm opening in the carb at idle, and this has to be set with the idle screw NOT the radio trim
