Car Nitro & Gas Engines Discuss all aspects of Nitro and Gas rc car engines here!
Problem!!!!! HElp!!!!!!
Old 04-20-2006 | 04:14 PM
Default Problem!!!!! HElp!!!!!!
my engine starts fine and runs fine until you hit the brakes, whats wrong with it, it would be much aprciated
Old 04-20-2006 | 06:55 PM
Default RE: Problem!!!!! HElp!!!!!!
check your linkages and idle adj screw. if all of thats fine then check your clutch
Old 04-20-2006 | 06:59 PM
what do I check the linkages for,what should i check the clutch for and what should the idle screw be turned to?
Old 04-21-2006 | 10:02 AM
check the clutch to see if the shoes are melted or if the springs are weak of broken. you want at least a 1mm opening in the carb at idle, and this has to be set with the idle screw NOT the radio trim
