RE: Next Steps programming DX6 and Trex SE??
Consult
Yes and No. I started up one time and new they were out(it was obvious)the COG was about 1/4in off. They are really hard to get tracked right. They will track though. Even after I got them balanced and tracked the start up was still rough. The heli would shake hard right before the blades stopped turning. So I took them off and put the wood blades back on and the shake was gone? Don't really know what caused the shake. I decided to try them again when I painted because I could sand them and actually have a nice finish that matched the heli. After I got done with them and put them back on the heli they were still hard to get tracked but once i got them tracked they ran perfect. You would think that CF blades should be perfect right out of the package since they cost so much. IMO I would rather have wood blades that matched. I have read that the tracking issue stops if you have the cnc flybar assembly though.
