RCU Forums - View Single Post - G38 engine mount
Old 04-23-2006 | 07:54 AM
mrbigg's Avatar
mrbigg
My Feedback: (21)
Default RE: G38 engine mount
By looking at the prop hub, I was thinking it was aftermarket. I put it up to the plane to show you my problem. Hard to see, but the cup mount is against the firewall.
Edit: Hey, Ralph look at the last pic. Your conversions go in the cup mount right? That would mean the flywheel and coil would be removed and it might work. As for right now, removing the cup mount alone doesn't do me any good because the muffler is in the rear.[:@] The prop would still be sticking out pretty far also, unless you could do something with it.
ID:	449960   Click image for larger version
ID:	449961   Click image for larger version
