RE: Diff oil and set ups
The biggest clutch bell I have used is the 14T and I think anything bigger is a bit overboard.
Also depends on motors torque characteristics.
I use 14 tooth with my Black Magic as its got lots of torque ,it also helps to tame throttle response when having a good bottom end motor.
Diff oils I run 5k,7k,1k on smooth high traction track I run 30k center.
