Diff oil and set ups
First, thanks to everyone who has helped me out thus far. Im haven a blast with this buggy.
Ok, on diff oils, what would you recommend? The track Im running at has a good straight away and about 11 to 12 turns 3 of wich are hard lefts and a right. Plus, they redo the track every year so its going to be wicked fast. I though about 5000 front and center and 3000 rear on the oils. What size bell? Think I have a 15. Its bigger than the stock one I know that.
Cool, thanks, any other tips or info I should know, my first race is friday and I have 5 days to gettr done.
The biggest clutch bell I have used is the 14T and I think anything bigger is a bit overboard.
Also depends on motors torque characteristics.
I use 14 tooth with my Black Magic as its got lots of torque ,it also helps to tame throttle response when having a good bottom end motor.
Diff oils I run 5k,7k,1k on smooth high traction track I run 30k center.
