RE: Tower Hobbies KAOS
I just bought one. Based on what I've read, a lot of the previous problems have been corrected. Tracks quite well. The only real problem I've had to this point is with the control rods, but that's related to the use of "park flyer" adjustable connectors between
the control rods and the servo horn. I fly on a pretty rough grass surface, so replacing the adjustable connector with soldered
clevises cured the problem. As far as the nose gear, it's pretty strong considering the beating it takes on our field. I'm going to replace the stock gear with a Fults dual one.
Other than that, the plane is pretty sound.
