RE: Please help - water problem
Check the head bolts for tightness.
As you can see in the shot below, I pulled mine off and rotated it 90 degrees as I don't like the idea of having the water inlet over the top of the carb.
It still has to be something inside the boat that is allowing the water in as to why I'm thinking the head or coolant lines if it's only getting water in while running.
