RCU Forums - View Single Post - McCullough 38cc Question
Old 04-25-2006 | 11:53 AM
captinjohn
Default RE: McCullough 38cc Question
flyrc100: How mutch end play do you have in the crankshaft with this 38cc Mac engine? If the end play is not mutch...run it. Check later and if end play gets more....then work on it. Maybe you can install a thrust washer now while it is apart. Good Luck Capt,n
