i and i forgot u need more fuel pressure like with out the supecharger the fuel pressure is higher than the free air pressure and u need however much pressure is in ur fuel line + however much boost ur making with the supecharger and a little more to clear up the lean ness so what are u gonna do try toput a fuel pump welll the one thing u can do is get the rb innovations pressure thing that goes in the line from the exhaust to the tank that lets exhaust pressure in but not out and install that in the exhaust pressure line then there is a auxilliary pressure line from the supercharger and install another of those things on there and maby it wont be to lean so richen the carb a bit and the fuel air ratio will be proper but still u can only get so much into the cilinder barley more than stock if any when the point of a supercharger is to jam that s*** in there and the turbo banshees can make some sick power but they have exhausts and everything designed for it and the turbo and the turbo blows through the carburator on the carburatedones and it works fine because they have a needle and seat and are not pressure fed they are gravity fed and the way the float bowl is the boost just dosent affect it its like running it at a lower altitude with more air pressure
http://www.trickracing1.com/home.html
and i think thats all i have to say about this
