RE: Small AD Rafale Test Flight
I use bificated exhaused pipe(as you say:dural exit).It is customer-made by one local factory in my country and I believe you can got it in USA(example:Tam Jet).Now the technique to make bificated pipe
is so good that it will not reduce much thrust.Therefore,you don't need to sacrify the reality.
