RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 04-28-2006 | 10:11 AM
  #74
Don M.'s Avatar
Don M.
Default RE: Venus II
In reply to setting up the stab. After measuring from wing tip to stab tip on both sides and getting that straight, block your wing on each tip on a table / floor until it is dead level and then adjust your stab until it is also equal distance on each tip in relation to whatever the plane is sitting on. I do do this on rare occasions but usually just eyeball it, but I eyeball from further back than 3 feet, maybe 10.
I built a Goldberg Ultimate one time that ended up with a twist in the right bottom wing panel. Try as I may I could not get that twist out. I was going to build a new wing panel but thought I would try it anyway. I flew that plane for 1100 flights that way and even won several IMAC contest over the years.
Bottom lines, do the best you can but don't get your "knickers in a knot"
