RE: PROBLEMS PROBLEMS PROBLEMS
Those temps are way too low. You should be around 200 atleast. It's probably just a little rich. Try leaning out the high speed needs about 1/8 a turn clockwise. Take it for a high speed pass and see if the bogging gets better or goes away. It probably just needs a little tuning. Don't worry so much about the idle until you get the high speed fixed. Get that running really good then you can idle it down or up and adjust the low side for good takeoff. There is a good tuning guide floating around here. I will see if I can find the link.
