Pattern thoughts - half reverse Cuban eight
Scoring clarification: Keith you are close.
All manuevers are scored 2 points per 25% off position. Therefore, if the entire manuever was done out of the box and it was otherwise perfect, it would be a 2.
Likewise, a centered manuever performed totally to the left of center would recieve an 8 point downgrade as well.
The reason it usually comes out as zero is because it's less than perfect too. Man those points add up quick =)
These are AMA rules of course. International rules may vary.
-Mike
