Fuel
Cool Power 30% Heli Pro.....
its Cool Power but Orange in color.....Morgan also makes a 20% heli pro also...same stuff less stink....The 30% really has a better idle and smoother transition....
I know that other manufacturers of fuel have come up with a DZ blend...or a Low Vis blend....These should work....
Last year running the DZ I found the absolute best results with the Cool Power 30% Heli....nothing else compared...I'm talking 15-20% performance....I tried them all....now this was before the low viscosity fuels came out especially formulated for the DZ.....I was running std pattern or Heli blends....
The COOL POWER WAS KING of them all! Not only that but my motors have lots of time...one was prototype and it has in the area of 500plus flights...the other was a pre-production motor that was identical to the production motors...It has about 200 flights...both of these save some 70 flights of trying fuels are now exclusively run on the Cool Power 30% heli pro.
YS plug, 16.5-12W or 17-12 APC prop and a 20 oz regular (crank) Tettra tank and the foam clunk supplied with the motor...Its a perfect setup.......
Troy Newman
