Predator tail set up
John I use both the Prism 7 and Eclipse for my Q500's and for both the travel functions on rudder ch4 and elevator ch2 are set at 50% . For the eclipse go to page 25 in your manual 'setting up V tail mixing' and it will walk you through it step by step. You will have no trouble getting the throws. From there you will most likely reduce throws with DR.
John
